How do i got this solid red material to look like the original clay. (if you know what i mean, not to clear with the terms)
I just want it to not look flat.
Thank you
Thank you
Is the program in Flat render mode, not Preview? Render palette, make sure the active mode is “preview”, not "Flat
Have you filled the object with the Flat material? Make sure any polypainting is off to see the active material previewed (Tool> Polypaint > Polypainting deactivated)
The default Zbrush Material is the Red Wax Matcap. If that’s what you want, press the Material selector on the left shelf, and select red wax from the pop up.
turn on M and color.fill object
yeah i pressed V and somehow it fixed it. weird. thanks guys
