Material artifacts on subtool?
Heya folks. This is surely a novice predicament, but my subtool doesn’t fully switch to a new material when I switch to a different one. It leaves behind coloration artifacts…see the image for an example. Even if I go to Color>Fill Object, it just doesn’t work. I don’t want to export/import OBJ files if I can help it, because I have subdivision history I don’t want to lose.
I’m fairly certain that it’s not just another subtool intersecting it…
What should I do about this?
You can reset the material by filling it with the ‘Flat Color’ material in the Standard Materials palette. Turn on ‘Mrgb’ button. Select ‘Flat Color’ material. Go to ‘Color’ menu and click ‘Fill Object’. Now select a different material for the subtool.
that’s exactly it…thank you!
No problem! :+1:small_orange_diamond:)
