Masks, Lazy mouse and shortcuts
Hey im having some problems with my zbrush 4.
The first one is when i use the control shift for masking and release the shift before releasing the click don’t work as its should, it doesn’t obey to the order of the releasing shift, its like if i were clicking control and shift all the time =S.
The other problem is with my lazy mouse, its not working when i try to use it for masking =S.
And the last problem I’m having is that sometimes zbrush doesn’t respond to my shortcuts at all… I need to restar computer to make zbrush react to my shortcuts…
I work on a mac btw…
Pls help !!!
Thank you…
Try press Alt instead of releasing the shift key
With the Ctrl key held down select Lazymouse from the stroke menu. Sculpting, Masking and Selecting are all treated separately.
Can’t help on this.
