Hello.
I’m new to masking, up to now I’ve been sculpting a ton but today I’m learning masking. I am working on a building in ZB, I want to use some alphas to sculpt planks onto the sides of the building. My plan was to mask of each side, go into Projection Master and alpha in my wooden planks. My problem is masking of a single flat side, I can’t find out how to get a perfectly straight line, or select a set of polys specifically. I can post a picture if that would help?
Regards.
E.
EDIT: Here is an image, is it possible to select just a couple of faces and mask the rest?
