Masking Problem with ZB4
Hi there,
i´ve a problem with masking in ZB4.
The Problem:
I would marking few polygons (with polyframe on) to create polygroups.
I use crtl/shift with rectangle for example and let go shift to make the marked polys visisble. The Rectangle doesn´t change to red.
Another Problem is that not visible Back Polygons (in Front View of the Modell) are also marked.
Has anyone a solution or Workaround?
Thanx and sorry for my bad english.
Regards
Martin
You now need to press Alt key before releasing ctrl+shift to turn your mask red.
Thank you Extra Dimensional!
It sounds like i´m getting broken fingers:D but i´ll test it tonight!
But what about the marked backface polygons? (don´t know if i have backward masking on in the masking palette because i´m not sitting in front of my pc yet)
I´ll check this too!
Once more thank you. The solution in 3.5 for this was better!
Now i have check red mask with alt tab. Everything´s ok with that but the problem with the masking in the back still exits.
[](http://www.zbrushcentral.com/zbc/faq.php?faq=vb_read_and_post#faq_zbc_display_images)
Excuse me,I dont understand your point…
Ok once more,
I´ll masking a modell in front view to create polygroups and change the topology for the eyes or other things.
I use ctrl/shift and rectangle to mask some polygons…so far so good but when i turn the Modell around in the back of the modell you see that there is also a mask - i don´t want this.
(Many Thanx for your Answer!)
