I had the same issue. I needed to apply simple dots with ctrl masking. But every time you do that, it thinks you are doing a single quick control click to blur that mask. To me, if the click results in applying even a small amount of masksing, it should not auto blur it.
Sure, you can set transpose blurring to 0, but that seems odd. You’d think that’s only specific to the auto blur transpose topology masking does.
I wish I can just turn off this ctrl blur thing, but still have that slider control for just transpose masking, and just use the blur mask button on mask. But turns out, that slider also effects that button. So if you set it to 0, the blur mask button does nothing. I wish there was a different slider right in the masking window for that.
The one slider effects everything and is deep in the preferences
