Try to mask by AO and the masking itself works well.
But if I click in the Texture Map Tab “New from masking” it is all in the second color I picked on the left… and u can see no depths…
can anyone help?
edit: same with cavitiy…
can anyone help?
There are currently issues when creating texture maps from masking. As a workaround you could use the mask while filling with color and then create a map using New from Polypaint.
oO
Never thought that way.
Thank you, I will try this!
