Masking a 3d object like painting
How do I selectively mask an object with the painting tools like in that pirahna video on the zbrush features page, where hes pulling out the teeth? Id really like to know. Thanks
Hold down the CTRL key while you are in edit/draw mode, then just start to mask away …:wink:
he ctrl-drew in edit mode like mentioned above.
you want to mask the areas you wish to work on only then go to tools:masking and hit inverse so that everything else is masked exept the area you wish to work on.
