MASK Intensity?
THREAD:
http://www.zbrushcentral.com/showthread.php?p=87163#post87163
What controls the MASK Intensity?
Sometimes to get a dark mask you have to click drag over the vertex several times.
ZB 3.5R3
Settings:
RGB = ON
RGB Intensity = 100
Z Intensity = 100
The Tool>Masking>Intensity setting will affect this.
Also, you will rarely get good results trying to mask a single vertex. The masking system works best when operating across entire polygons.
The Intensity was already set to 100, I thought something else would contribute to the intensity like RGB or something.
Thank you!
RGB intensity slider does control per stroke masking opacity.
When you are modeling you will be doing it so fast that somewhere you hit a hot key combo that lowers the rgb intensity. Hold down the Cntrl key and check the rgb intensity while it is depressed, set it back to 100 and you will be in business.
This is for people searching this topic.
