UV Map->GUVTiles
Masking->Mask By Cavity
Texture Map->New From Masking
produces cavity mask with white errors as can be seen in image
UV Map->GUVTiles
Hi bgoreta1,
did you mask on the highest subdivision level? Because masking is done per vertex, so if the resolution is too low, it may look broken.
Regards
I had to press fixseam under texture map tab, that fixed the white holes.
