im trying set the size of my displacement map texture
but i don’t see where i set the size of the map.
it just gives me a default of 1024.
i thought it would be under the displament map menu.
If you’re using 3.12 or higher you set the map size per SubTool, using the Tool>UV Map menu.
Thanks
