I installed z4r4. Everything seems to work but many brushes are missing. Curve Strap is one that I feel I really need is there something I’m not doing properly? I went into lightbox and looked under brushes and then under curves still no luck. do I need to reinstall the update?
The tutorials were made with a beta version. The release version had a slight change where several brushes were combined into the IMM_Curve brush. Simply select that brush and press M. You’ll see a pop-up with not one, but two strap choices, a couple tracks and several other options.
