2 Questions here:
- How do I manipulate Surface Noise through a Zscript. Want to be able to set strength, mix basic noise, offset, the alpha to use, flip h, and set it to uv. Currently all I can get it to do is open the GUI and then the Zscript gets stuck. Here’s what I have so far.
[IPress,Texture:Texture Off]//3D Panel Generation Begins
[IPress,Tool:Plane3D]
[IPress,Transform:Fit]
[IPress,Tool:Make PolyMesh3D]
[IPress,Tool:Surface:Noise]
[FileNameSetNext,“ZBRUSH_\ZStartup\ZPlugs\GreeblePlugData\3D_Depth.tif”]
[ISet,NoiseMaker:Mix Basic Noise,0]
[ISet,NoiseMaker:Strength,0.15]
[ISet,NoiseMaker:Noise Curve:Offset,-0.01]
- With Decimation Master, how do I execute it with certain parameters, such as Pre Process with UV and Decimate to certain Polycount like 20K Poly all in a Zscript.
Thanks in Advance
Glenn
