Man
I´m sending some tests of recent studies. I hope you like it.
[attach=34976]render_public.jpg[/attach]
[attach=34977]render_z1.jpg[/attach]
[attach=34978]render_z2.jpg[/attach]
I used 3d Max to build the model an then ZBrush to improve and add details in mesh. For the final image I adjusted the levels with Photoshop.
Regards,
metaballs
It’s very, very good!
I’m currently learning Zbrush and I have started to wonder why I don’t see the ears in the maps you’ve created (and several others too). I don’t know that much about UV’s and stuff, but do you make a separate UV-layout for the ears? They are attached in the same base mesh I suppose?
Sorry if I “highjacked” this with a question =)
But for the images: I’m truly impressed! All thumbs up!
//M
Great , beautiful and wonderful job! :eek:
Congratulations!
your bad character!
JayMan,
Zbrush is a great tool. I reduced the map in order to visualize quickly. The ears are in the same map but I used unwrap. If you use 3d max you will see a new feature called Pelt that make things easier.
Thanks for your comments!
metaballs
