Man With Visor. textured, untextured.
My first actual head other than a crappy monkey.
It was kinda hard to texture, cuz i cudn’t just texture it once then put three of it there. I had to texture all of them witht the simple brush. i did not use texture master.
Without texture
Please tell me what you think.
Hi Twiggy,
texturing without Projection Master (ex Texture Master) is a bit difficult :slight_smile:
The FiberBrush should be used with flat color after baking image.
Use antialias working with double canvas size.
Nice modelling and expression.
cameyo
as you can probably tell… i am very noobish. what does baking a layer do?
Baking Layer:
  1. technically: all the pixols are converted to flat material retaining color and shadow,ecc
  2. practically: the tools of ZBrush works different on a baked layer.
The normal use of baking layer is for postprocessing image with 2D or 2.5D tools.
To bake a layer you must press Layer->Bake button (or press Ctrl-B)
There are tons of info on Quicklinks section…better than my info :wink:
ciao
cameyo
