Hi there, still getting to grips with Zb and was wondering about the following things:
I am used to seeing and would find it useful to be able to see the tri-axis marker on screen all the time. I know that I can use the floor and if positioned correctly I can see the axis. Was wondering if it is possible to always have an on screen tri-axis indicator aka Modo etc.
When I press F my item always fills the screen a little too much - is there anywhere I can say not to zoom in so close when I fill the frame? (suspect I might be missing something more fundamental and that there is a reason it does this!). For example could I have F fit and centre the selected tool at 70% say? Can’t see it in the prefs.
Many thanks
Steve
