Flat lines Well I have a cyborg Model And I need to make flat lines in it.
Ive played with Alphas Focal shift Masking etc.
The only way I can make a flat steady line is to mask it and use and alpha square I made in photoshop which is essentially a White line in the middle of a black layer.
It makes and ok line But I would like to use a brush.
I used Flatten brush already. And different brush settings.
Does anyone know a good trick.
using standard brush and ZSUB produces a V line not a flat surface.
like the ^ instead of like this _.
So if anyone knows and can explain please do.
once Again Im making flat lines on a circuit board what are your best options in Zbrush.
I could a Boolean and a 3d app but that wont go back into zbrush.
