when I try to use Ctrl and shift to cut out portions of a mesh to make edge loops, the Ctrl + shift works just the opposite and does not cut out what I select. This is annoying, as I want to be able to cut out what I select.
found out what I was doing wrong on making edges. When I use the lasso and have to let go of the Shift key first to select the mesh I want out…thanks anyway
