hi,i’m wandering how to drop each brush to the bottom space [as shown in the pic]…plez reaply
Preferences–>Custom UI–>Enable Customize.
Then control-click-drag buttons to where you want them docked.
Don’t forget to turn off ‘Enable Customize’ when done and save the result under Preferences–>Config–>Save UI / Store Config.
i’ve noticed that for some reason you can’t drag your total poly count/active poly count down there and expect it to save… it always seems to disappear after each restart.
wonder why that is…
thanx man
don’t know dude… some one will help
Yeah… noticed that too.
There are a few other buttons and sliders that always seem to go missing. Particularly when placing them in the bottom tray on the right hand side.
Also noticed that not all buttons work (reliably) when mapped to a key. The side trays for instance. Hope they fix these little problems.
ActivePoints and TotalPoints can be placed on the Shelf. Launch ZBrush, but do not load a tool. Enable customization and immediately place those elements on your shelf. They will be grayed out, which is fine. Save the UI.
Basically, they won’t save to the UI if a tool is currently being read by them.
sweet, good to know.
I’ve been dragging those things down to my shelf every time I loaded ZBrush for the past year, it’s become a ritual
