Make Polymesh Button
Greeting,
I simple question, I hope. My “make polymesh” button does not work. I am just starting with Z Brush, following the tutorials and I’m guessing I did somethign to turn off the Make Polymesh button ???
Any suggestions ???
Thanks in Advance.
Michael
We’ll need more info to help you out.
Are you in edit mode?
Can you enter edit mode?
If you can’t, clean your canvas (ctrl+n), then draw out your mesh on the canvas again. Go into edit mode (T). See if you can make polymesh now.
Hope this helps.
Thanks for the reply,
Yes I was in edit mode , it worked earlier in my trying, so I’m thinking I did something or could it be that my computer can’t handle the process. It was a simple sphere with + 8000 points
It works now, I ran the disk cleanup and restarted.
Just too much temp stuff, I guess.
Thanks
