Make Polymesh 3D Broken? (Answered)
I just got my new Z4 installed. I loaded up a ring primitive, masked it and inflated abit. Then I hit “Make Polymesh3d” And it didn’t work. The button does not seem to do anything anymore.
Anyone else seeing this?
Win 7 64 bit.
Thanks,
Dan
EDIT: I restarted Z4 and now everything is fine. Maybe the auth process leaves z4 in a wierd state. O.o
Yeah I saw the same thing earlier today. Have not tried it again yet to see if it has resolved itself.
Once I restarted haven’t seen any other problems so far. :stuck_out_tongue:
I can also confirm a restart after closing the initial startup with activation now does work “as advertised”.
Make Polymesh3D broken for me too (Windows xp x64). Waiting zbrush 4.1???
Did you do the same thing we did? Quit zb4, and restart it after activation?
Yes, it didn’t work after I restart zb, but some time later it started do what it must. I don’t know what exactly helped.
I restarted and reinitialized zbrush several times and the issue its still present
Hi, i have read but dont remember in which topic that if you have your primitive selected and in edit mode, then you press the import button and cancel and then press the make 3D Polymesh you get finally the conversion to…:smiley:
I have tested this and it works as expected. If you did not resolve this issue please fill a support ticket at https://support.pixologic.com/
