Make a shortcut for "Brush imbed" settings
Hello
I would like to make a shortcut button for the “Brush imbed” settings.
We can found this option under, Brush>tablet pressure>Brush imbed
i would like to have a sort of button to change this value. A button that would look like the draw size, focal shift, Z intensity and so on that we can see on top… A cursor that we could slide…
Any tips ?
Thanks a lot.
You can assign a hotkey to the Brush>Depth>Imbed slider. Then when you press the hotkey the slider will pop up at the cursor. Simply Ctrl+Alt+click on the slider then press the hotkey you want. Press Preferences>Hotkeys>Store to have the hotkey work each session.
There’s no way to create a slider to adjust the Tablet Pressure>Brush Imbed curve.
Thanks a lot.
Another question.
I want to add the “smooth stronger” and “smooth directional” brush icon.
I go to lightbox>brush>smooth and ctrl+alt click and drag to put it where I want.
I save UI and store UI but each time I start zbrush, these 2 icons are not there anymore.
Any idee how to fix that ?
Thanks.
Copy the ZBP files for those brushes from the ZBrush 4R3/ZBrushes/Smooth folder to the ZBrush 4R3/ZStartup/BrushPresets folder. Then they will be loaded automatically each ZBrush session and will show up in your custom UI.
Perfect.
Thanks for the tip and this extremly quick answer!
Thanks.
