When using Turntable Plus, I am experiencing a peculiar behavior.
First, I record the start middle and end scenes and adjust the modifiers to allow 360 images per rotation and maximize quality.
I use image sequence export with tiffs (though I really wish that png was an option as that is the format I usually use for image sequences).
The first image is as expected. The model then rotates a good 20 degrees and then starts exporting normally. Until it gets to the end. The last image is never the stored last scene, and is also not a full 360 degrees from the 2nd image, which was not the stored start scene.
This forces me to export 3 full rotations to obtain a single 360 that will loop correctly.
Anyone else experiencing this?
Thanks
Cheers, Chuck
