Hi all.
Isn’t the Mac subtool master (multi append feature) supposed to automatically append all items instantly without showing a dialogue box for each object (like the Windows version)?
What am I not doing right?
thx
Hi all.
thx
For technical reasons the Mac version works in a slightly different way but with the same result. Instead of shift+selecting a group of files you select one each time from the Open dialog or press Cancel when you’re done. Any ZTL you select will automatically have all its subtools appended.
I see. Will this be fixed or no? I really need this to work like the windows version. There will be times when there are just too many parts that make up meshes I’m working with and to click “add, add, add, etc” times 20 or 30 is a bit much.
It seems like a simple fix but if not I guess I’m once again stuck with the Windows version.
How’s that zappLink for Mac going?
I think it should be possible to implement a ‘select all’ option for files in a folder. I’ll see if it can be added when SubTool Master is updated.
I’m afraid I have no information on ZAppLink.
Thank you again Marcus.
Also, any word on the version 3.5 release?
