Hi all.
How can i make a lowpoly model in zb?(make evry thing in zb)
Thanks and bye
Hi all.
Thanks and bye
zspheres are a good way to start.
if you set the res in the transform palette to 1 before you start then the zspheres should create the minimum amount of geomertry to define the shape.
you should also look into retopo and normal/displacement maps, to get the best out of a lowpoly model.
good luck
Tnx for your help!
A next qustion:
Can i change me highpoly model to a lowpoly?
(In zb)
Thanks again,and bye
if the model was subdivided in zbrush then just reduce the sub level,
if it has come from another package or you have deleted the lower sub levels, then you may be able to use the reconstruct subdivides to lower the ploy count.
however this works best when the model has been divided in zbrush and will not work if the reduction will create tri’s.
try viewing some of the vids in the zclass room ( theres a link at the top of the page)
hope that helps:)
ps
redoing the topology and then projecting the higher detail is another good way to keep your high detail whilst still lowering the poly count ( normal or displacement maps will be required to see high detail on a low poly model)
Tnx a lot for helps and link.
Ok,i have a question again:
Can i make evry think by box modeling in a lowpoly?like human wiht a nice details.
Thanks and bye
box modeling is realy only for base meshes in zbrush to add high detail you will need to use the sculpt functions.
if you wish to produce mid res characters with out sculpting you should try blender www.blender.org
and yes pritty much any thing can be box modeld (as long as your good enough) however most people prefer poly by poly for creating humans.
try reading the documention for zbrush most questions are answered there http://www.pixologic.com/docs/index.php/Main_Page
Tnx a lot!
Have a good time
I have a problem with box modeling tut.
I did evry steps like tut but my cube…
Is this a problem or not?
And if this is a problem,how can i fix it?
Sorry for my bad englishe
Have a good time
