Hi Guys. With the help of this forum, I was finally able to merge my subtools and keep the edges from having a gap using the crease button prior to subdividing. Once my paint and sculpting is done, I then split the tool back into groups. From there, the subtools lost there UV’s when I try to export the maps!!! WHY? Please help : (
There’s a small “Uv” toggle button next to the Merge button; was it enabled when you merged your subtools together?
Thank you for the reply. Let me go back a minute and simulate the situation and see…
NO, it was not enabled…
i hope i’m wrong but unless you made some duplicates with the UVs, your only hope is quicksave.
maybe one of the quicksave files will have the tools before you merged them.
I actually have been saving the tool in every stage prior to trying to doing merge tests : )
