Lost the stock meshes that came with R2 .Help [Solved]
Hi I customized my interface the other day, and today on a project I wanted to test out the apend, >hand <that came in the stock meshes, and all of the new meshes are gone , have no clue where they went! I have a backup image and can access all the files from previous setup, but have no clue where these meshes are stored,hand, foot,head, etc! Thanks in advance!Any help would be apreciated ! Can reimage or copy file.!
I’m not sure which meshes you are talking about. Are you thinking of the Insert Mesh brushes? They have a hand, head etc. and you’ll find them in the main Brush palette. The default projects and tools are still available through Lightbox, though you may need to look in one of the new subfolders as Lightbox has been reorganized. Both Lightbox and the Brush palette should not have been affected by your custom interface.
If this doesn’t help please post an image of your whole interface as requested in the ‘New Policy’ announcement at the top of this forum.
Yes those are the files I ment ,sorry for the short posted question, for some reason my original posted question only put up the first line! of several! I am looking thru files now, and searched every folder, with no luck, also mounted two backup images and they were missing there also! I installed a pixal pusher UI and some brushes a while back, which may have been the cause, am making a back up image, now and will do a reinstall and compare files to see what happened. will post results, to save others the problem thanks. DJ
:confused:They were there under brushes , I must be having a dislecsic day! I was looking under the subtools append button popup list! Thanks DJ
Glad you got it sorted. :slight_smile:
