Lost Button
Ok maybe not lost, maybe misplaced.
Am following along with a tutorial from Digital Tutors and they press
a button on the lower bottom of the right hand side under the polyf
button callled Trans ( transparencey).
I ain’t got it.
If I change interfaces can produce it in two other setups, but
in the default mode, Digital Tutors has it, I don’t.
Not that big a deal, but, if that button is missing, maybe more.
Please note there is no reward for the return of the item in question.
Comments such as I have lost my buttons not welcome:D
Look in your Transform menu.
Button is in the transform menu, many thanks.
I can also change interface setups and see it in a few of them.
But.
In a few tutorials, Digital Tutors and others, are using the default
interface and they have the button on the right lower side.
I don’t.
Just wondering why.
Did you go to Preferences > Config and do Restore Standard UI to make sure that you did indeed have the default UI?
Many thanks zber, found it, kind of.
Did as you suggested, no button…visible on screen.
But
When I put my mouse below what was visible saw a tool tip
saying it was there.
Must have to do with screen resolution.
Mine is 1024x768.
In any case nice to know noone stole it, will work around this.
Thank you very much for your help, appreciate it.
Wasn’t the button itself, it was an implication that something
bigger was wrong.
Your welcome bicc39!
OK! I see. Yes, I think ZBrush 3.5 and 4 do tend to favor wide screen monitors.
Might be useful:
http://www.zbrushcentral.com/showpost.php?p=734962&postcount=11
