Lose detail when using transpose master to get higher scale
Using transpose master to scale a lot a model (10 or 100X) with subdivisions will result in losing a significant amount of detail. When higher is the scale the higher the lost.
Any workaround or solution?
Probably better to use the Size slider in the Deformation sub-palette, and then press “Repeat to Other”. You need to set the slider once only before doing the repeat.
