Looking for help on background Panorama's
I’m using lighting backgrounds & can seem to get the right angle, or the panorama is to close. I zoom out because its already set on -1. Is there a tutorial or a site that can help me? I’m wanting to set up the background with better lighting. Thanks You!!!
It sounds as though you are not loading a panorama image. If you apply an ordinary photo to the background then it may appear zoomed in because the image is being stretched through 360 degrees. You can see the type of image required in the Texture palette - look at Texture 01 (the inside of an art gallery).
There is some information about the Background here:
http://www.pixologic.com/docs/index.php/Background
