Hello.
The problem is just what the title says. Is there is a way to do so?
Hello.
Get this and install it>> http://www.zbrushcentral.com/showthread.php?161588-quot-Axis-quot-Plugin-for-ZBrush-4r2
Then read more. Forums are searchable too.
Not really what I was looking for but thanks anyway.
The list of things possible to do is too long to post. What it can’t do would be shorter I think. Learn how it(the software)works by reading and experimenting. The Axis thing helps considerably. Knowledge is power
You can turn on your timeline slider and set a key for the location you want to store.
While this doesn’t remove the ability to move your object, it does give you a fast way to return to the stored point if you happen to move your camera. Axis plugin can do this, and you can also store views with Zapplink or Imageplane.
