Location of the master configuration file?
I am looking for the location of the master configuration file (the one that gets overwritten when you press Store Config). The online documentation is incomplete, as it only says the following:
The master file is named ‘CustomUserInterface.cfg’ and resides in…
http://docs.pixologic.com/reference-guide/preferences/config/
I did a search for ‘CustomUserInterface.cfg’ through my Computer and it did not return any results.
Best regards,
Patrick Eischen
Not sure if you found the proper location. There is a UIStandard.cfg found in C:\Program Files\Pixologic\ZBrush 2021\ZData. There is UIstandard.cfg file there.
I think that is the file you are looking for… Hope it helps
Its the file “CustomUserInterface.cfg” stored in C:\Users\Public\Documents\ZBrushData\ZStartup
