Hello, I’m a newbie to ZBrush. My issues is with both loading a tool and appending a model with another (I use 3.5 R3).
My models are facing the opposite direction when I load them (back towards me). Even the files in ZBrush such as Super Average man are doing this.
I just rotate the tools to start working and save them this way, but it happens every time. The other issues is when I append one model to another for referencing, they are facing opposite of each other.
Thanks for the help.
zbrush looks at Z backwards…the same goes for V with UVs.
So if you build an object somewhere else…what you had as the front (+Z) zbrush sees as -Z. It doesn’t really matter unless you’re using deformations and then you need to take that into account.
I’m not sure why things are facing the wrong way for you after import/append though.
