Under the Tools/Surface menu after you click on the Noise Curve title & open the curve form dialog there’s Save/Load options. Can you only load Noise that you’ve previously made with the curve dialog & saved or can you load an image for Noise? If so that format? :o
I think that it only lets you load and save .zcv files so you can reuse your own custom curve settings. No images though, tried it.
OK thanks rem. I figured that because I tried loading a texture from the Texture folder & that didn’t work. I noticed there’s no folder in the ZBrush 3.5R2 directory that’s untitled Noise. Would it be alright to create a folder in the ZBrush 3.5R2 directory or would I have to create a folder outside the program folder?
