Is this a common problem? I have a model that is built in 3.1 it will open in 3.5 however if i try to load in 3.5 i get a “load error”
Is 3.5 not compatible with earlier versions?
Any insight would be appreciated
you may want to re check what you wrote…
so it loads okay into 3.5…but doesn’t load and gives an error?
3.1 models load into 3.5r3
3.5 models do not load into 3.1
export from 3.5 if you have to… as obj then load into 3.1 and reconstruct subdivisions.
Hi Cresshead, my bad you are right.
I built a model in 3.1 loaded it into 3.50 to use some of the new features.Saved it and tried to open in 3.1,thats when i get the load error.Your steps to resolve this will help.Thanks
why would one WANT to go from 3.5R3 to 3.1 ?
I use 3.5 at work but only 3.1 at home.
I needed to take a 3.5 back to 3.1 today because the zproject isn’t working. I just exported the mesh as an obj and it opened right up. Then import back into 3.5.
