I’ve just started experimenting with creating different materials, saving them and then loading to use on other models.
Can anyone tell me why, when you load the material onto layer 2 does it apply the material to the model on layer 1?
If I load the material first, but then select a standard material, then draw the model and then apply the loaded material it applies only to layer 2, which works just fine.
Is this a bug in ZBrush or am I doing something wrong?
Also - why does loading a material delete the current material in the material preview window? If this is to make room on the toolbar, how do you get the deleted material back? Would you have to re-load?
Any pointers would be gratefully received.
