loading custom UI (.cfg) from 4.0 into 4R2b > customs menus are missing.
just switched from 4.0 to 4R2b. tried to load my custom UI, it works except my custom menus are missing.
Did a search on the forum and found the UIstarter plug but it still doesn’t work. As I understood it anyway, it’s supposed to fix the empty menus problem not the one when they are completely missing.
is there a way to do it or will I have to create them all over again ?
thank you for your answers.
There have been a lot of changes from ZBrush 4 to 4R2b. That is probably the reason.
Ok then. I’ll do the menus again.:confused:
