Loading aTool made in 3.5 into 3.1
I need some of the plugins available for 3.1 right now but I need the new brushes of 3.5 also. So I thought I’d be able to make my tools in ZBrush 3.5 and then load them in 3.1 so I can run the plugins on them. Doesn’t seem to let me do that though. So I’m wondering is this not something I can do or am I simply not doing it right? Is there an option for saving in a 3.1 compatible format (if not there should be)? I thought a tool was a tool but I guess not. Am I forced to export OBJ and sacrifice subdivison levels in order to go between the two versions?
Also…I hope you guys at Pixologic do the logical thing and incorporate these plugins into the main ZBrush 4 app. I mean, things like Decimator, Subtool Master,etc. should be included out of the box in ZBrush 4. Since there’s more time to work on it, I hope that’s part of what’s being done. It’d sure make a lot of folks happy…well, maybe just me but whatever.
Thanks in advance.
-T
I am sure there are other threads also covering this as its been brought up many times. This is one of them.
http://www.zbrushcentral.com/zbc/showthread.php?t=75217&highlight=3.5+tool+3.1
Richard
Sweet. Thanks. I checked the knowledge base first - knew I should have checked the forums. :slight_smile:
