Hi. when I load old ZTL files (possibly 3.5?) into 4R7 all the subtools are “spikey” and messed up.
I’ve done quite a bit of searching and haven’t found anything. Is there a way to fix this?
Thanks!
Thanks!
They should be OK if you load into an earlier version of ZBrush - 4R6 or 4R5 - and resave.
Also try using the 32 bit version of 4R7. Most of mine open fine in the 32 bit version. open, then resave, then it will open in the 64 bit beta.
