Win Vista 64bit, Zbrush 3.1, 4gb of ram
You can see my problem from the topic. I was happily Zbrushing and then i had to restart Zbrush - after restart load material button is not usable? Restarting Zbrush doesn’t help.
I tried removing some of the startup files, but i think it’s not a good idea as i don’t clue where the fault might be.
Before this i was using imageplane 3 but i’ve never had any problems with it. I also added one matcap material and saved it and i then tried to remove it from startup material folder but this didn’t help either.
I have a clean copy of Zbrush 3 folder which i haven’t yet tried to restore, (licence?) but i think it would be nice to know if there is some sort of exact solution to this, as i wouldn’t like to re-install all the plugins.
Thanks in advance!
