I have a large model with 300K polys wanted to Boolean it but does not work. I tried on simple primitives
and works. So whats the strategy for Boolean organic high poly models.
Regards,
Simon
Regards,
Simon
I use Live Boolean all the time on super high poly meshes and subtools. Select the tool you want to boolean “into” and click the Start arrow on it’s subtool name. Then make sure the subtool you want to Boolean “from” is visible in the subtool palette and that the little closed/open/intersect shape is properly selected and then move it around. By rights you should then see the Live Boolean process happening in real time. When you click Make Boolean Mesh you’ll get another Ztl up in your tool menu of the combined result you can then append as a new subtool and delete the subtools you started from if you wish and work from there.
