Dear sirs, I apologize in advance in the case that this rubrique isn’t exactly fitting for suggestions’ posts, but indeed I didn’t found any place better than this among the remainder ones. In the contrary case, please move this thread in a more fitting place and delete this highlight.
I would like to suggest you some things for the next release.
I know that zbrush is a solid application (I admit it is the best in the market, for its field), and that you eventually wouldn’t welcome any critiques (either constructive or less), 'cause you feel to “dictate the rules”: and I’m aware that many people who use it daily could rather critique my highlights not yet 'cause the interface and the working method are really functional per se, but simply 'cause they didn’t got other choices than getting absorbed by them as they was conceived by zbrush’s coders.
I’m afraid, infacts, that zbrush could be rendered even more user-friendly for anybody, if only you would follow the rules of common sense and usual interfacing (which comes from studies and trial&error since the existence of personal computers). I guess that you had in mind something “different” when you first coded this app, and I know that it is difficult to sail away from the beaten track when an app’s name has been consolidated: though, I think that sometimes it is worthful to avoid a completely drastic separation from “common thinking”, in order to avoid also eventual issues with wide usability.
- You may begin first off from putting three typical “close”, “minimize” and “maximize” buttons instead of the current ones, which are really ennoying. Whatever would be their graphical appearance, it isn’t important: what’s important is just that they close, maximize and minimize the GUI the same way as we see for the 99,99% apps in the world. It would be very appreciated.
1a) Same as for the headbar: please use a File, Modify, Tools etc. system…
You may considere to eliminate that useless, meaningless, ridiculous starting cursor (don’t you like a normal waterclock / pointer cursor? Too “banal”?) and arrange the GUI so to leave visible the windows’ taskbar; it is really ennoying to get absorbed by the work and don’t even being able to look at what time it is in the taskbar…
What’s the purpose to save either a document and a tool? Just use only a file with *.zbr format extension. I guess that this will solve also several problems like the failure to load a given document (for which issue there isn’t any solutions so far, than “multiple savings”…) after hours of modeling…
The zsphere should be put apart, 'cause it is a very important element for structural constructing. Either do this, or arrange in another way the library that contains it: it is both ennoying and ridiculous to scroll down a tiny pointerbar in order to reach the 46th place to pick it up…
4a) You may remove the “basic shapes” library (that with hound, bust etc.) from the top shelf, and put it into some other part of the top bar’s writings (e. g. “Tools”).
- You may considere also some snapping options, some precise measuring tool, and some commands such as hollowing and thickening.
5a) Something to clone a brush around some path, filling the targeted area so that the brush is spanning its entire area (mean, the repeating brushes tile themselves without gaps inbetween eachother).
- A standard way for inserting referencing images and planes, instead of using those DIY crossing flat wafers.
This is what comes immediately in my mind: though I guess that there will be more to come…
Thanks for your attention. Regards.
