Lights and shadows are wrong
Hi, after making my face and hair from zero, I found out that after render the entire object turns black. Or most of it is embed in a deep dark shadow.
I have iniatialize several times and does’ t change.
How do I reset this?
How do I turn to normal render?
I m new to ZBRUSH, so maybe I did change something and now I do mot find where.
Thanks to help me
Cris
Hi Cris.
Can we get a look at this? Without further information, what you describe could be an issue with the scene lighting, or an issue with the material you have assigned. You can drag and drop images directly into the text window here, and it will upload them to the thread.
Well, the issue is scene lighting and rendering settings are stored in a ZProject file. So if it’s an problem with your lighting or material, every time you re-load that project the potentially problematic settings are loading with it.
If you can’t track down whatever settings are causing it to render oddly, it might be best to port your model to a fresh scene entirely to get a fresh start. To do this, save your tool out as a tool file (Tool > Save as), then restart with program in an entirely new session, and import the tool into it (Tool > Load).
ZBrush Document17 ![ZBrush
the object not render
Document17a|1092x648](upload://km4lw78cxNQ6NdCw2qc2R1RXP7I.jpeg)
object rendered.
Those are my issues. No need to say I’m staring with zbrush…and I’m doing as exercices…form PolySphere or Sphere 3D
Thanks to guide me.
Cris
