Hello everybody;
i can´t load the new alphas from lighbox to my alpha palette, always that doubleclick with hold shift on it, appears in the texture palette and i need to make a alpha from that texture. i don´t have two monitors like i read in the thread… How can i put it directly to the alpha palette?
thanks very much for read it.
If your alpha is going to your texture palette then it is probably not a true alpha in the sense of being an 16 bit greyscale image (and not just black/grey/white rgb image). Try this out: Shift click so the alpha in question goes to the texture palette. From the texture palette select “make alpha”. Then from the alpha palette select “export” and export this converted alpha to your lightbox alpha folder. Try shift double clicking again on the new version to see if it now goes right to the Alpha palette.
Edited to correct grammer and missing words…I swear I wasn’t dipping into the eggnog when I wrote that!:o
Thanks a lot friend.
I download it from the download center- alpha library. I will try this method but when i send it to texture palette changes the black,grey,white rgb image.
thanks a lot another time
