In the documentation it says this
"If you would like to access your own folders in the Other tab just save all of your
Texture, Alphas, and etc in the ZBrush>ZExportImport folder. How when you click on the
Other tab all of your folders will be there. " --their spelling mistake btw
I’ve tried this and Lightbox doesn’t see any folders…what i actually would like to do is to be able to browse with Lightbox various folders of images on my HD’s without having to copy them all to the Zbrush app folder.
Am i missing something really obvious?..likely:D
Using a mac btw if that makes any difference
also this:
“You are able to save shortcuts in LightBox. If you have an external hard drive you
can put a shortcut in the ZBrush3.5>ZTools folder so that will always be there when you
load LightBox.”
Is this implying that you can save a shortcut to specific Ztools that are on a hardrive or a shortcut to the actual drive? As no shortcuts i save are seen by Lightbox in any folder
Cheers,
mala
as the Alias
(on lion)
