Lightbox only showing some items
Setup: ZBrush 4 on Ubuntu 10.10 through wine.
ZBrush runs beautifully but lightbox does not show all items. Everything seems to work as expected otherwise.
For instance, when looking in the Projects tab(in lightbox) I only see the Mannequin directory and nothing more, as if Projects only contained Mannequin. Inside the Mannequin directory I only see 4 items (mnan scene1, dog1, 8headed female,rhino) even though others are in the physical directory. I can open up the others through zbrush, just not in lightbox.
Interestingly enough, if I delete, say, rhino so it is no longer in the directory, then refresh lightbox, then it shows me a few other projects that it didn’t show before.
Another thing I tried, I downloaded several matcaps (from the zbrush site) and placed them in the materials folder. None showed up in lightbox. I moved them all out and tried just putting one in and it worked in lightbox. I put them back 1 at a time and was able to show 9 total, anymore wouldn’t show up, and if I put them all back, they all stop showing up.
By the way I can load any of the projects, as mentioned, as well as the matcaps through the load dialog, just not through lightbox.
All permissions are set to all access for all users also, so that doesn’t appear to be the issue.
Any help would be much appreciated, thanks!
Also, I discovered that if I create a folder in the materials directory one of the materials disappears. Almost as if 9 items is all that it wants to display.
