Lightbox not turning off at startup
- enable the customization
- TURN OFF Preferences>Lightbox>Open at launch
- Store the config
Every time the config is saved with or without customization on, the “Open at launch” button turns on.
It is annoying, that bit.
But mine doesn’t open at launch most of the time. Tried loading a .zpr file from Explorer(assumed you’re using Windows)? If you crash the program it will be open for certain next time it’s launched.
It works if : Document> Save as startup Doc
It does not work as a Custom UI
STEPS
Also this is a great script:
How do you change the Redwax Default start up Mat to another for start up?
