Lightbox and normal Polypaint combination
Hi there,
I have a model, what ist colored with normal polypaint (and I have also got UVs already, but this should not be the problem).
No I want to combine the normal polypaint with a lightbox texture, a normal .jpg. I also have to protect several parts (which should be preserved from Lightbox painting) by a mask.
After polypainting I cancel the mask and let ZB produce a texture map. The lightbox painted areas work perfect, but the (former) masked part with the none-Lightbox-Polypainting appears only in black, that means, the initial poly paint dissapears.
Any help for me?
Greetings
Stephan
Hi, I just found a thread with the same problem, and aurick is already engaged there:
http://www.zbrushcentral.com/showthread.php?163158-quot-New-From-Polypaint-quot-is-creating-a-solid-black-texture
Lightbox ???..Don’t you mean Spotlight?
…sorry, you´re right…
