light problem
Hi
I am from Poland so sorry for my english :slight_smile:
I was wondering what is wrong with my zbrush, because when I am changing the position of the light it doesn’t change the light source on my model, but if I click BPR render it does.
This is problem because I can not check the light position without clicking Render button…
Why is that ?
Thanks!
Is it a MatCap material? Those materials have the lighting baked in and won’t respond to what you do in the Light palette. Any materials not under the MatCap heading in the Material palette will respond to your lighting.
Hello,
You can only change the lighting on the basic materials. If your model has a MatCap, the lighting is already defined. It sounds like you may be using a MatCap.
Try using a basic material and then play with the lights and render with BPR.
Hope that helps.
Cheers,
