Light Caps Not Updating
I’m currently having and issue where I have a model at about 8M points and and some polypaint info and some light cap info and for some reason now it doesn’t want to let change my light cap settings, meaning any changes I make do not show up on the model and the light cap samples on the spheres do not update at all. The file is about 2.5GB and I was wondering if this is the problem or if there is a known issue with light caps not updating. Any help would be great, thanks!
click on “light” up top and see if the light buttons are turned off, if they are turn the top left one on.
if it’s not that, perhaps you filled your model with MRGB or M turned on or you converted a texture into polypaint.
try turning on M then switch to “flat” material and fill the model with it. that restores the materials to normal.
